Enables or disables MAC address tracking for all MAC addresses on the specified ports.
| add | Enables MAC address tracking for the specified ports. |
| delete | Disables MAC address tracking for the specified ports. |
| port_list | Specifies a list of ports on which MAC address tracking is to be enabled or disabled. |
| all | Specifies that MAC address tracking is to be enabled or disabled on all ports. |
No ports are enabled for MAC address tracking.
MAC address tracking events on enabled ports generate EMS messages and can optionally generate SNMP traps.
When a MAC address is configured in the tracking table, but detected on a MAC tracking enabled port, the per MAC address statistical counters are not updated.The following example enables MAC address tracking for all MAC addresses on port 2:1:
configure fdb mac-tracking add ports 2:1
This command was first available in ExtremeXOS 12.4.
